メインコンテンツにスキップ
Appleの消費者向け人気ラインのMacBook Airの修理ガイド
4817回答 すべてを表示
MacBook air 2012 late turns off
Hi, Got a MacBook air 2012 late, With light water damage..
With some problems, To turn it on you have to disconnect battery and then plug charge in and it turns on by it self ? maybe a keyboard problem ?
When on it turns off in around 30 seconds? and the backlight does not work.
The light on the charge did not come on when plugged in, There was a bit of corrosion on the io cable connector ! so changed cable with new! this fixed the problem with charger light..
Please help many thanks ..........
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Put your motherboard in a ultrasonic cleaner.
So you don’t have any corrosion on your motherboard.
If that still doesn’t work you will have to inspect the motherboard.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi Yes cleaned the board, I found out that the keyboard was turning off the MacBook ..
but the backlight does not work ?
さんによる
コメントを追加
回答を追加する
EON さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 60
