メインコンテンツにスキップ
Appleがプロフェッショナルおよびパワーユーザー向けに提供するノートPCのラインです。現在、MacBook Proには13、14、15、16、17インチがあり、Pre-unibody(オリジナル)、unibody、Retinaディスプレイ、Touch Bar、SOC(システムオンチップ)設計によって大きな改訂が定義されています。
20033回答 すべてを表示
My trackpad barely reacts to clicking, onyl "touch" clicking
So, I noticed this problem a couple of days ago when I was on facebook with my mac. I was pressing the home icon on facebook but the mac did not respond. I then pressed really hard (mechanical click) and it worked.. this keeps happening all the time.
The "touch" click works perfectly but the mechanical click is almost non-responsive. It really annoys me because I like using photoshop with the trackpad but because of this problem, click and drag etc, is more or less impossible.
Do any of you have any suggestions on what could be wrong with it?
I have never spilled anything in it, never dropped it on the ground or so on. I've always been really careful with it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
4 件のコメント
I appreciate all response!
さんによる
I might really help to know exactly which MacBook Pro you have as trackpad technology has changed recently.
さんによる
Well, I got it when I was about 15 and now I'm 18, so in 2013 ca. I believe it's a Macbook Pro 13", (A1278)
さんによる
Please don't guess. Go here and enter your serial number, it's either in fine print on the back or if your battery is removable in the battery compartment or under the Apple in "about this Mac": http://www.everymac.com/ultimate-mac-loo...
Also please unaccept the answer until your problem is resolved.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hello,
I am sure your battery is going bad. Is swelling and pushing in to the trackpad, causing the trackpad click to be unresponsive and you need to push harder on it. A new battery will fix this problem.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Thank you! I will try sending it in for repair and hopefully this will solve the issue. This mac has lasted me quite a bit and a lot longer than my other computers. It's a trustworthy "comapnion" hahah
さんによる
They are very good computer and they are made to last. Let me know after you get the computer back how the trackpad is working.
さんによる
I will! thank you so much!
さんによる
コメントを追加
回答を追加する
Marina Halvorsen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 1,960
