メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
My iPhone is charging but does not transfer data
Everything started a while ago (I think) I had an original lightning cable for over 4 years, I used it to charge everything, including the 5S, at some point, this cable stopped charging on one side, but on the other it still worked!
The problem now is that I need to connect the iPhone to my computer and it doesn't gets recognised.
Yesterday I replaced the lightning port with a new one, but still does nothing, I need help, please :(
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
6 件のコメント
Does the computer see it in recovery mode? Are you using a usb 2 or 3 port and what OS and itunes version.
さんによる
Nope, not even in recovery mode
Usb 3.0, Mac mini 2012 OSX 10.11.6
iTunes version 12.5.1.21
さんによる
Just to make sure. You did try a new cable?
さんによる
I have 2 cables (both new), one charges only on one side, and the other one charges normally, on both sides
さんによる
well it can be the somhow werd ios update to 10 i can only charge in the wall transformer bifore i culd charge the ipad using my TV and a old pc now i say LADDAR INTE all the usb say the same =_= apple is realy making thing break by themself and the cable well i have lost 5 for 1 ipad i think and i show you how apple make your orginal cable and this is the cable after it broke inside i took off the cover and holy ^#% is this the strong point its the weak the midle have a cover but stops just bifore the usb abd the ipad male side =_= heres how it looks like when i saw the inside
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
Does it have any liquid damage?
It may be a possible IC charging chip issue.(soldered on the board) This is worn out by using uncertified chargers or charging blocks.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
In other words, non-MFI certified lightning cables and bad quality charging adapters / wall chargers.
さんによる
It does not have any liquid damage, but I had used a micro usb to lightning adapter, maybe that did the damage :(
Because I use an original wall charger
What do you think, is it worth the risk replacing that IC?
さんによる
that adapter for sure could have done the damage.
A power IC isn't that expensive and its one of the larger (read: easier) components to replace.
さんによる
So, you say that if I can find someone who has some experience, it's not so complicated, right?
さんによる
Btw, I saw that the picture you uploaded is from an iPhone 5, is there any picture of the 5S IC?
さんによる
コメントを追加
回答を追加する
germang31 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 44
今までの合計 4,888
