メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
iPhone 5S not charging EVEN AFTER replacing U2 IC?
I gave my Iphone 5S to a repairing guy who’s a friend of mine.
He doesn’t wanna buy new U2 IC, he has got few spare motherboards and he insists on removing the IC from them. Till date he has tried putting 4 such IC’s but no gain. I can buy new IC online and give it to him but he tells me not to do so, he will manage.
First of all he tested the charging port & ribbon which leads to the motherboard. That’s not the culprit. He is sure that the problem must be with the IC. But it’s been more than 50 DAYS since the phone is lying there, he still hasn’t come up with a solution.
I think that if I buy new IC online and give it to him, it will work.
Anyhow, my question:
1. Apart from the charging port & ribbon & IC, is there anything else responsible for charging the battery? I mean even if he puts new ribbon (with charging port) and U2 IC, is it possible that the battery still won’t charge?
2. What other solution do I have? Take it to official apple service center?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
2. Apple will either offer you a out of warranty replacement for the phone which will cost money or they will not help you at all.
Take it to a mobile phone technician that does board level repairs such as changing the tristar u2 charging IC. Replacing it is not a easy task. Better to leave it to someone that is experienced in doing so.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Put charger to iphone without battery. Check 5v vbus, if not voltage this or voltage is down, jumper q2. Last solution reball u2, ic pad not connected to pcb
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Arpit Kumar さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 7,132
