メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Phone heated up and then went blank. Does not start again
While playing a game on my iphone 6, the phone started heating up. Could not close the game even by pressing the home button. Suddenly the screen went blank and the phone continued heating up. Then I removed the SIM and it gradually cooled down. Thereafter the phone does not start and neither does it get charged. Any clue on what could have been the problem?
Had taken this to the apple authorized repair shop, however, they did not look at the issue, only advised me to get a replacement by paying almost $400. Not convinced with this approach.
I would like to know if anyone has faced this problem before and what could be the possible problem and solution.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I would say immediately hold the power and home button for 10 seconds but it's too late now. Sounds like the power management ic has overheated or at worst even the CPU (Do iPhones have a separate GPU chip? I don't know.) which is probably a goner.
さんによる
コメントを追加
1 件の回答
ベストアンサー
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
Did anything happen to the phone prior to this event? Sometimes drops, other physical damage, repair attempts and water can cause these types of failures. The issue could be modular in nature, for example a failed sensor or camera that suddenly starts goes "short-circuit" and draws excess current from the battery.
Likewise, it could be a failure on the logic board itself. The only way to properly troubleshoot this is to probe the logic board and do board-level diagnostics. Apple will only offer to replace the device but today there are many repair shops that specialize in micro-soldering repairs.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Sagar Javkhedkar さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 73
