メインコンテンツにスキップ
iPad Miniは7.9 インチのディスプレイで、容量は16、32、64 GBがあります。
screen flckering after replacement
I replaced the screen/digitizer on my daughter's Ipad mini. it powers on and seems to function with the touches etc but the screen flickers and looks horrid. It gets brighter and then dimmer every 5-10 seconds and you can see the previous screen faintly behind the current image, especially when the light gets dimmer. There are also horizontal and vertical lines distorting the image. I didn't glue down the cover yet and am wondering if maybe the LCD connector isn't seated properly. I am definitely not an expert (I replaced my friend's Ipad 3 screen quite easily) but this was so much harder! Any thoughts would be greatly appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hello! It sounds like 1 of 2 things based upon the limited information I have. Either the LCD screen is defective or it was not installed properly. You can buy another screen and test that theory or double check your installation. Without seeing the device it is hard to determine.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
SPAM - half your answers promote this Drive Savers Repair Shop.
さんによる
コメントを追加
回答を追加する
karen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 63
