メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
iPhone showing black and white stripes
Hello!
My neighbours iPhone is only showing these black and white stripes.
When I change the display it's not showing anything (and I tested the new display on my own phone it definitly works!)
The old display sometimes shows these black and white stripes and sometimes it turns full white then black again.
My PC however seems to recognize the iPhone and it's also showing up on iTunes.
But it seems that I can't find a fix for the screen problem.
Here is the screen:
http://i.imgur.com/XjVKN12.jpg
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi there,
This youtube video might help you: https://www.youtube.com/watch?v=nJCZJwrk...
In which he opens the phone up, cleans all the sockets that attach the screen to the motherboard with a toothbrush, and then secures the cables back into their sockets.
Note that he is working on a 5s, in order to open a 5 you can follow this guide, which is essentially the same but without the booby trapped cable connected to the home button that you will see in the video.
iPhone 5 スクリーンの交換
Hope this helps!
このアンサーは役に立ちましたか?
スコア 4
5 件のコメント:
Hi, I'm gonna try that, also cleaning with 100% alcohol and puttin' a new screen.. hope that works
さんによる
Okay, it's not the display. I cleaned it with alcohol and it's still only showing these black and white stripes.
さんによる
Aw man, I wish I had another suggestion for you, but that was my best guess... I'll keep searching the internet and let you know if I find an explanation.
さんによる
Thanks, ye I think I found some posts on some weird russian forum saying that it's an issue with the board. Some circuits are screw'd (seems to be a common problem with 5c's tho) - welp thanks for your help anyways. I think I'll just sell it on ebay, cause from the outside it still looks fine.
さんによる
This is happening to me to, I am doing this on my computer, this has happened two times before but the phone usually worked again after a couple of hours. I know this was like 3 years ago and it probably is working again so any tips or should I just wait?
さんによる
コメントを追加
回答を追加する
dieuhientran63 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 18
今までの合計 13,762
