メインコンテンツにスキップ
Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
27回答 すべてを表示
Can I replace the cord on my shark vacuum
The cord on my shark lift away, the prongs are about to break. Can I replace the cord?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 15
6 件のコメント
Where did you order the power cord from?
さんによる
My Black Lab just Chewed the plug in Part off the Cord Last night, Thanks for the Thred.
さんによる
My puppy chewed my cord today, couldn't believe it! Oddly comforted to see I am not the only one and perhaps this is common puppy behavior. Thanks for the steps, hope it works on my shark vacuum since its a bit different model.
さんによる
My dog chewed the cord to my shark rotator pro NV500 into pieces. Will these same steps help me?
さんによる
You’ll need to order the whole canister with the plug, it does ta come separately. I would
Call shark. They are VERY good at responding and getting you the parts you need. They have a very good warranty too.
さんによる
1以上のコメントを表示
コメントを追加
8件の回答
ベストアンサー
Thanks for posting this, I successfully made the repair. My wife ordered a new cord right after our puppy decided to chew on it. Yes, it was unplugged!
Those images will help you take it apart, CLICK HERE for a complete set of pics! I hope this helps someone out, and I am sure someone will comment there is a better way to make connections. I am sure there is, but this worked perfectly. My only advice is, keep each screw with each part. Take your own step by step pics, they really helped in making sure I put the wire protector parts back in place correctly. Happy Ifixing! (ifixit.com, feel free to use these images!)
— Spencer from CT
このアンサーは役に立ちましたか?
スコア 14
7 件のコメント:
Same story, Spencer from CT, dog chewed through the cord in three different places before I even could plug it in and turn it on. Thanks for your very thoughtful and comprehensive details and instructions. Regards, mister_marv
さんによる
hahaha, same story here too! Glad to hear I'm not the only one that has to keep cords away from my puppy! Thanks for the instructions!
さんによる
amazing. my dog chewed mine this morning , im so relieved …. really could not afford another vacuum right now
:D
さんによる
I had no clue how to replace my cord. I can take anything apart, your pictures saved me on putting it back together. I must say it made feel important when the vacuum actually worked. Thank you
さんによる
Thank you for this. I'm actually attempting to replace the cord. Could I take a cord off of an old vacuum that I dont use anymore instead of buying a new one and having to wait for delivery. The other vacuum cord has the same wires / 2 prong. ...looks pretty much the same
さんによる
2件以上のコメントを表示
コメントを追加
YES YOU CAN, cause I just did.
Ordered the cord from Amazon $18 or so.
remove the dirt canister and vacuum head. remove all the screws from the bottom of the canister and pull the cover off. inside you will see a plate with 4 screws, remove this. Now you will see the crimp on wire nuts, I didn't have these so I just simply used twist on wire nuts and tape.
Reassemble and vacuum away. Easiest repair I've had to make on a household appliance.
Hope this helps.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Me too and I am 72 and have never used anything except a screw driver and a hammer so this was a challenge. But I DID IT !! I could not have done it at all without Spencer from CT - see above. I spent two hours searching YouTube etc and there just isn't any good tutorial out there. I did run into some snags tho' because I am such a rank beginner. I used to make instruction manuals as part of my job, so I wrote it up in even more detail than Spencer used. The file is 2682 KB tho' so I don't know how to get it to you folks. Can someone help me with that? Cz
さんによる
Hi @czchick ,
Here's how to create a guide on ifixit.
Creating a Repair Guide.
さんによる
Sharon, did you ever post the step by step guide? Thanks D
さんによる
コメントを追加
Another option is replace the plug only, if the dog chewed close to the plug. That would shorten the cord a little. Or cut of the cord where bad and put a new plug, then use an extension cord. Hide from dog !
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Ok so my German Shepard Zeus just chewed my shark vacuum cord in half. Where do I order a replacement cord?
さんによる
コメントを追加
So I did NOT have my dog chew through the cord, but I did pull the plug from the wall and one prong was still in the outlet. Hmmm....I happen to have an identical spare Shark for parts, so I am going to attempt this repair with the above advice. I kept looking at it and thought surely I can do this. I'll let you guys know how it went.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Yes you can... you can do it your self (if you feel confident in taking the vacuum apart) or you can take it to almost any vacuum repair shop and they will do it...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Also at the moment there does not appear to be any guides for the top half of that vacuum and if you did it your self you would most likely need to do some soldering
さんによる
コメントを追加
Great pics, thank you! Easy repair - the small orange wire nuts for #18 wire work well. Be careful not to over-tighten the black screws when putting back together as the heads will twist right off - as I did for the first one :/
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I don’t have an answer. My cat chewed my cord. Is it safe to put the black electric tape around it?
Pictures did not help me. I’m sure they are excellent, I just have a problem seeing the detail.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi,
It is safer to replace the cord. Saves a lot of potential problems from occurring in the future.
Electrician's tape is best used on wires/cables where there is no movement in the wires and it is out of sight/contact with people
If you can't manage it yourself perhaps you know someone who will be able to do it for you especially with some help from the advice above.
さんによる
コメントを追加
Most of the answers are not for the Shark Rocket model HV301, the motor is on the top of the stick and once you remove the screws for the top cover there are 4 additional screws that I can’t remove. Removing those 4 screws would get me to the motor and the cord attachment.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi @amelilli146
Given that the original question was about a Shark Navigator Lift-Away Pro NV370, it is understandable that they do not relate to a HV301.
Post your 'answer" as a new question on ifixit and add some close up images of the problem screws. Perhaps someone may be able to help you.
Here's how to do this.
iFixitでの質問に画像を追加する方法
Perhaps the screws of the "tamperproof" variety and is this why you are having trouble removing them.
Have you seen this?
Shark Rocket HV301 Fan Replacement
さんによる
コメントを追加
回答を追加する
whitewesties1414 さん、ありがとうございました!
統計データ:
過去 24時間: 16
過去 7 日: 132
過去 30 日: 705
今までの合計 72,102
