メインコンテンツにスキップ
The Golf Mk4 was first introduced in August 1997, followed by a notchback version (VW Bora or, in North America, again VW Jetta) in August 1998 and a new Golf Variant (estate) in March 1999.
35回答 すべてを表示
Broken cigarette lighter - Fuse problem?
So the light around the rim comes on when I turn the lights on, but it doesnt seem to work. Tried plugging my sat nav in and got nothing, although it works in other cars. What do I need to do and how? Please help me
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Yes
it could be a fuse. Look in fuse box for blown one - often inside the cover of the box it tells which fuse is for what.
If the new fuse just blows out then there's a short in the unit (or wires leading to the unit). If you find the short it may be repairable, or you may need to replace the unit.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
The light in the rim and the lighter itself are two different circurits. As said before look for a blown fuse.
さんによる
To add to the info above: Power outlet is #26 (20amp) and the Cigarette lighter is #24 (25amp)
さんによる
Only have 22 fuses, none marked 12v outlet, car does not have cig. Lighter.
Light around outlet does not light up,
2002 G L X.
Unplugged from back no power, which fuse should it be?
さんによる
コメントを追加
Hello I have a problem in tidying up not working for four golf 4
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Krystyna さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 17
今までの合計 8,285
