Consistent dripping sound coming from tank
There is a consistent dripping sound coming from the tank of my toilet. What could it be?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Over time the flapper - which is soft and supple new - becomes dry and hard. Replacing the flapper will normally fix a dripping issue, and it's about a 5 buck repair.
このアンサーは役に立ちましたか?
Try putting a new tank kit in it?
このアンサーは役に立ちましたか?
It may be time to replace the whole kit soon anyway. As there is no visible water leaking from the tank and no overflows ever, I just wonder what it might be.
It' cause of a bad flapper, it can't hold the in the tank and the water is dripping from the tank. You should replace the toilet flapper asap.
このアンサーは役に立ちましたか?
過去 24時間: 6
過去 7 日: 24
過去 30 日: 48
今までの合計 17,550
