メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
20回答 すべてを表示
Cell antennae signal weak
Hello all!
So the Lightning connector went bad (unable to charge when plugged in) so I had a local shop repair it. After that, it seemed as though the phone had a hard time acquiring a cell signal but I couldn't pinpoint the blame on the repair shop.
Question: Is it possible that an antenna connector/connection was left loose? If so, does anyone have a picture of the antennas that control that? If needed to replace, would I replace the logics board? (assuming the antennas are connected to it)
Thanks for any and all help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Thanks! I'll give it a shot when I get the repair tool kit to take it apart. Thanks again!
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hello,
If the issue was not present before the charging port replacement, then the sudden loss of signal is most definitely stemming from the replacement. As always, before proceeding always make sure to soft reset the phone by holding home and power button simultaneously for 30 seconds. If problem is still present, try steps below.
1. You should check under the battery connector cover, if the gold antenna connector isn't plugged in, plug it in.
2. If the connector is plugged in, you need another charging port. Charge port issues, while rare, still occur. Sometimes the solder from the antenna connector on the charge port is loose, or improperly done. A new charging port should fix the issue.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
And no, you don't need a new logic board
さんによる
コメントを追加
回答を追加する
Keith Baldwin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 187
