What I do after land in water
My dji landed in water then its not started so what i do
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Rice is good to eat but does nothing to fix the problems caused by a mix of liquids and electronics.
First remove the power from the device, then follow this guide about how to clean the device and hopefully get it working again.
このアンサーは役に立ちましたか?
Hi, I have a bebop that took a swim. I placed it in rice which helps absorbs water and placed the container in the direct sun over two days and at night I put it in a box with a light on. Took it out and fired it up. It works , the only down side is the camera is a bit blurred.
このアンサーは役に立ちましたか?
Hi guys. I dropped my dron in the water. I will try it to do that think with rice if will not working any one of you guys know some one who can help?
There is my email address: bkosinski21@gmail.com
Thanks
Bart
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 411
1件のコメント
I can only suggest what to do. Try putting the DJI drone and batttery into rice. It should remove moisture and give you a better chance of recovering the drone.
Imad Knight さんによる
