メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Toshiba Satellite M45は、パワフルで持ち運び可能なマルチメディアコンピューティング向けに設計されたノートパソコンです。15.4インチのWXGAディスプレイを搭載し、Microsoft Windows XPで動作します。プロセッサは1.6GHz、512MBのRAM、80GBのハードドライブを備えています。
Laptop doesn't power on!
Battery went bad, by the time we got a replacement installed and charged. When I push power button to turn on, all I get is 4 beeps! Does this 3 times, then shut off the power indicator light. Nothing shows up on the screen. Any ideas? Thanks in advance for any help! Les G
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Possible that your memory needs to be re-seated in the slot. Try and re-seat the memory and then reboot.
If that doesn't work..
Check to see if any lights flash/light up in a certain order. Look up Toshiba Satellite M45 error codes and try to figure it out from there.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I tried this after seeing your reply- didn't work. Other than two lights under the F10 & F11 keys that come on for a second, when the beep code begins, nothing comes to mind. I'll return to Toshiba's website in a bit to check out that search. Thank you!
さんによる
コメントを追加
Take the battery off your laptop and put on power and see if it works then and if it does its the battery as mine was the same and mine was a brand new battery, ? Good luck
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks CoCo for the reply, had tried that before posting, actually even before ordering the new battery. This is a very old laptop, software resets aren't even available from toshiba anymore. I'm an OS X user, but I needed a Windows machine to see if I could help out a friend get some pics off of her old HD.
さんによる
コメントを追加
回答を追加する
Les さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 327
