メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
Why is my iPhone not responding to charging?
I've tried to charge my iPhone once with an unauthorized cable, it didn't charge and after that I couldn't charge it anymore not even with an authorized cable. Eventually the battery ran out and I couldn't get the phone to power on anymore. I took the device to an authorized Apple provider shop and the technician opened it and tried to power on with a different battery to no avail. He said that it's probably the logic board. What could be the cause of this? And if it is indeed the logic board that is defective, is there any way to save the data?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
sounds like a common U2 ic chip problem, i would send it in for repair, where are you located? i would know someone that could help you with your problem
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
snow さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 101
