メインコンテンツにスキップ
The iBook G3 was unveiled in July 1999 as Apple's portable computer for consumers.
232回答 すべてを表示
"This Drive Has Reported A Fatal Hardware Error To Disk Utility"
Today, I decided to upgrade my computer's hard drive, I have an 800Mhz Solid White iBook G3. It had a 20GB drive, that I upgraded to 40GB (not a major upgrade, but i was running out of space) After the painstaking process of getting the thing open, and installing the drive, I installed OS tiger, and opened Disk Utility. When i got to the drive, it showed me the following message "This Drive Has Reported A Fatal Hardware Error To Disk Utility" and the S.M.A.R.T. Status was "Failing" the drive is a toshiba MK4025GAS that i removed from my old dead powerbook g4 (spilled coffee) and the drive worked fine in a USB enclosure on my PC, and never reported any errors. The drive workes fine to me, it installed tiger fine, and just to test it, i copied about 10GB of files to it, and deleted them, and did it again, and it still works fine. It doesnt make any strange noises, and the coumpuer is just as fast, if not faster than it was before. Could the drive be giving a false warning? It seems to be holding up great, and even though i could put the old drive back in it, i could use the extra space on the larger one. Any Ideas on whether the drive actually has a problem or not?
Thanks,
Chris
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Repairing the directory (fsck and Disk Utility's Repair Disk and Verify Disk) has nothing to do with a hardware failure as reported by SMART. Directory is software. Hardware is hardware.
I would dump this drive and replace it with a new one, without hesitation. They don't cost much. Though I guess it depends on how much you value your data.
To find out more, assuming you have at least 10.4.11, download SMART Utility which will tell you exactly which attribute(s) are failing. http://www.apple.com/downloads/macosx/sy...
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
just installed it, here's the info:
Toshiba MK4025GAS
SN: 34H552775
Capacity: 40,007,761,920 Bytes
Power On Hours: 1850
Temp: 31C
Pending Bad Sectors: 0
Removed Bad Sectors: 0
Start Stop Count: 6066
Reallocated bad sectors: 993
CRC Error Count: 0
Total Errors: 0
Overall SMART Status: FAILED
anything that i didn't type here was just marked with a "-"
さんによる
It's failed. Dump it. Just because it might work to some degree right now doesn't make it trustworthy. 993 replaced blocks is a lot. If you do manage to reformat it with "write all zeroes", which maps out the bad blocks, in most cases bad blocks is a progressively worsening situation and it's just not worth risking any data with a drive like this. (Blocks = sectors.)
さんによる
Ok, thanks.
さんによる
コメントを追加
I doubt its a false warning- did you verify it as well? Since you could actually do a lot I think it may be a more minor permissions problem, but even fatal errors that are extremely dangerous can go unnoticed for a while, do a verify IMMEDIATELY.
Sounds like you got a bad drive though, so I'd just return it instead of trying to see if repair is possible.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
when i go to the drive page in disk utility, it just says "This Drive Has Reported A Fatal Hardware Error To Disk Utility" i can't get to the repair and verify options
さんによる
Looks like you're beyond much chance of repair, as a last attempt I suggest you boot into single-user mode and try fsyck -y
さんによる
tried that, it seemed to work fine, i also forced disk checking (fsck -f) and it produced no errors, it seems to me like there is no actual error, either way, i am ready to re-install the origional drive is nessicary
さんによる
コメントを追加
Hi, Let me see if I understand the problem
1. drive came from an old computer of yours--not new
2. it worked properly in an USB enclosure
3. in the enclosure you used it with a PC
4. you installed Tiger on it without problem
I am assuming you reformatted the drive to install Tiger and are trying to reach disk utility with the install disk. At this point I think I would probably do good backups and use the drive or remove it and place it back in the USB enclosure and use it to as a backup drive. Ralph
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I am trying to reach disk utility, in mac OS, and thats where it gives me the error.
さんによる
I wouldn't even use it as a backup drive. What's the point if its integrity and lifespan is in doubt?
さんによる
I agree==I only said as a backup because the OP stated the drive was working. Ralph
さんによる
コメントを追加
回答を追加する
Chris Green さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 6,784
