メインコンテンツにスキップ
Mac Proとして知られるデスクトップMacシリーズの2013年版新モデルです。
117回答 すべてを表示
Where can I get service manual for a Mac Pro 2013?
Mac Pro Late 2013W
I would love to built one of these from scratch, but trying to find the service manual for part numbers has dodged me for a while. So far I can get most of the parts but have no luck with screws and other things. Hope someone can help. Thanks ahead of time.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
We get this type of question about once a month about building something from parts. The problem is usually that the total cost of the parts far exceeds what the unit can be bought for as a whole.
UPDATE
I have changed the icon to the correct machine. Click on it to be able to see all the parts and the repair guide on it.
このアンサーは役に立ちましたか?
スコア 4
10 件のコメント:
Actually is the other way around. If you shop or call some of the distributors you can come in around $600 to $800 less than the machine costs. And with the Mac Pro hitting the 3 year mark, prices for the core components are actually cheaper. I built a Mac Pro 2009 the same way, and this machine still works flawlessly (at almost 7 years old), did flash it to 2010.
さんによる
What o you mean you flashed it to a 2010? I have both a 2008 & 2009.
You might consider looking for a cheap one with video problems:
http://www.macrumors.com/2016/02/06/late...
さんによる
@hijode - Apple lowered the price on some of the Mac Pro models last fall are you just noting the fact the distributers are clearing their stock?
Just like cars buying the parts to build a car, it's more expensive than buying the system straight up new. And likewise buying an older model when newer models arrive on the scene the older models will be cheaper, And lastly, buying a used system or even broken system is the cheapest.
The only caveat here is the country you are in could have VAT taxes or import controls that make buying an Apple system overly expensive were you live.
さんによる
And with the Mac Pro hitting the 3 year mark, prices for the core components are actually cheaper. And actually it is cheaper to put this machine from scratch. After all Apple is still selling a 3 year old machine for $3000. As for buying one that has video card problems, it makes no sense, you still have to fix the cards, right?
さんによる
How about reading this: To Buy The New Mac Pro Or Build Your Own? The Answer Might Surprise You.
BTW - Your URL is broken
さんによる
5件以上のコメントを表示
コメントを追加
回答を追加する
Andre Pacheco さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 1,418
