メインコンテンツにスキップ
The Blu Dash JR D140 cell phone was manufactured by the Blu company in 2013, their headquarters is Doral, Florida.
13回答 すべてを表示
says radio off when I try to make a call
Trying to activate the phone. The screen says removed sim card. The card is in but when you try to make a call the screen says "radio off" call not sent dial emergency #. Called Tag mobile, they said to try the sim card in another phone. We don't have another phone that takes the mini sim card. anyone with any ideas? This is a disabled client of mine, limited income, so has this phone and he needs it to work. Thanks to anyone who has an idea we could try.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
8 件のコメント
The sim tray may be damaged. Go to settings>about>status and see what you get for the cellular related info.
さんによる
My phone network is not coming what to do
さんによる
Can't make a call because radio off. What do I do please.
さんによる
I .may phone I see sine Radio off
What this min and haw this affect may phone
さんによる
Do you have a hey Google radio, turn it on then call all the numbers affected by radio off then when you've proved that they are now connected turn off First your mobile Then your hey Google, I don't know if it is the same with Alexa but this was my problem and I figured it out as I remembered I'd turned my hey Google radio off at the plug in the middle of the phone call, hope this helps
さんによる
3件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
the problem is probably that they already took down 2g towers this phone runs 2g so it would no longer work
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
What do I do?
さんによる
I have a BLU2. When this happens (Radio Off), I do a total reboot and on new start-up, problem solved. You can also try removing and resetting the battery.
さんによる
コメントを追加
@Linda Liggett wriglesworth Since the problem is 2G towers, you will have to get a new phone. Would you prefer a smart phone or flip phone? What carrier do you use?
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
My phone model is vivoY71
さんによる
Please give me solution. I can not Call any one because it show radio off
さんによる
@Most munni Khanom Get a 4G capable phone and get a new SIM card from your carrier.
さんによる
コメントを追加
回答を追加する
pris さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 33
過去 30 日: 179
今までの合計 16,158
