Any screen that is said to work on SM-G900 something then it works on all SM-G900 models.
Somewhat off-topic stuff away from question:
On Samsung phones you can be 80% sure that the charger ports will have to be the exact model or you will run into Wi-Fi / Reception issues and at worst charging issues (though I've never encountered this myself before).
For rear camera you definitely have to use the correct model number as camera has firmware that is different from other variants.
Same for antenna module too in some cases.
When screen comes without frame on samsung, most of the time it's compatible with a lot of models, but if it comes with the frame the compatibility with models drops as some may have different cut outs for logic board to fit with the component locations on the logic board.
Excellent. Thanks Ben, much appreciated.
Bigphilly71 さんによる
buenas yo he probado la pantalla en g900f g900v y g900h y funciona en todas
arturo marin さんによる
hi all i have a g900l the old Charge Port Assembly M just would like to know if a F assembly will go with the M assembly thanks
Cole court さんによる
Si tengo un g900h que otra pantalla podría usar ?
Moisés Lopez さんによる
Is a G900 screen can use on a G900A
dwayneelson さんによる
