My phone signal is not indicate when I insert slim card
My doogee valencia2y100 phone signal is not indicating please help for solution
Take out the simcard and clean it with microfiber if you have that (don't try enything else).
If that doesn't work,try calling someone and/or go to call settings and change Preferred Network between Global, LTE , GSM, CDMA, UMTS(depends where you're from) . Try it in a different phone if you can.
If neither of these worked the problem is most likely the sim card.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 7
過去 30 日: 9
今までの合計 235
