メインコンテンツにスキップ
モデル番号A1136/30、60、80GBハードドライブ/ブラックまたは白のプラスチックフロント
798回答 すべてを表示
not charging after battery replacement
Just replaced my old battery with the one I purchased from you. Great and easy fix, loved your instructions. But here is the problem, even with the new battery my Ipod does not charge. Originally I had a block charger that overheated and even melted. I of course replaced it and hoped that replacing the battery would fix my problem. It works fine while it is plugged in either a block charger or my pc but it obviously does not charge my battery.The battery icon displays full while the Ipod is plugged in. Do you think it is possible that I have a "fried" logic board?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント
Since I did not get any answers I figured what the heck and went ahead and order a logic board. Should be no problem with the manual that is posted on here. I let you all know how it went once I receive my new logic board.
さんによる
same thing happened to me. how it go???
さんによる
It went great ;) replaced the logic board and the iPod is still jamming :-)
さんによる
コメントを追加
1 件の回答
ベストアンサー
Since I did not get any answers I figured what the heck and went ahead and order a logic board. Should be no problem with the manual that is posted on here. I let you all know how it went once I receive my new logic board. It did work and the error was on the logic board.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
oldturkey03 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 13
今までの合計 2,676
