メインコンテンツにスキップ
このモデルは、SM-G530H / DV Samsung Galaxy Grand Primeで、白、グレー、またはゴールドのケースのカラーバリエーションがあります。
148回答 すべてを表示
My touch screen is unresponsive after dropping my phone
I have an 8 month old Samsung Galaxy Grand Prime smartphone. It has worked fine until I dropped it a few nights ago. Now all of a sudden the touchscreen doesn't seem to be working correctly... It will lag or stop responding or respond erratically. I tried several fixes including taking the battery out, restarting, doing a TPS grid check,putting it in safe mode and uninstalling and reinstalling apps, etc. It is still not working normally. I need to know what to do. I do not have a service contract or insurance, bought the phone outright and use straight talk.
Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
6 件のコメント:
The digitizer was likely damaged from, the drop, are there any cracks on the screen?
さんによる
Try taking it apart, unplugging the digitizer and use a bluetooth mouse to interact with the phone and see if the problem is fixed, if it is, replace the digitizer.
さんによる
The screen isn't cracked.
I have no idea what a digitizer is or what that means lol.. I'm not very tech savvy.
さんによる
I'd recommend taking this to a phone repair place, perhaps where you bought it? Usually they'd recommend the best option for you, or give you a replacement :)
さんによる
A digitizer is another name for touch screen. LCD is the liquid crystal display that shows an image on the screen, it is sometimes separate from the digitizer and it is sometimes fused together.
Depending on what phone you have of course.
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
Thank you. I bought it at Walmart so taking it there probably won't work lol. I found a repair place though, I'm going to take it in tomorrow.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hope it works!
さんによる
コメントを追加
回答を追加する
Jami さん、ありがとうございました!
統計データ:
過去 24時間: 14
過去 7 日: 84
過去 30 日: 332
今までの合計 23,319
