メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Camera wont take pictures.
My iphone 6 camera wont take pictures I can open up the camera app and see that the camera is working but when i click to take a picture it does the normal picture taking animation but nothing is saved, its very weird because when i switch to video mode the camera can take a video and save it like normal, any ideas of whats wrong or what part i should replace thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
4 件のコメント
I replaced the camera and still the same problem also flash isnt working
さんによる
i have the same problem but video won’t work for me either
さんによる
my iphone 6 doesn't take a photo or a video.. when i go to camera it only become dark even if i place the capture button it still dark no photo or video, i need a help plzz
さんによる
My phone does this too! It’s really confusing. I can take a picture and it’ll do the animation and stuff, but it just doesn’t appear in my camera roll! Even when I save something from the internet or screenshot something, it doesn’t appear in my camera roll. I wonder why it does this
さんによる
コメントを追加
8件の回答
最も参考になった回答
in my situation , both camera were not work , after change camera ic U2301 , all thing go ok , but photo not saved , the fix was so simple and easy , just change your time zone then back it to auto set from time setting , and thats all , camera now saved photo normally .
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Only to return what permission to take pictures of the same is not critical permission where do I go on my phone to get my phone better to take pictures help me
さんによる
コメントを追加
same problem here. no solution
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had this problem too but after rebooting my iPhone 7 twice the photos began saving again. Hope this helps
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This doesn't require replacing anything, because you said it takes videos. Have you done a hard reset? Hold power button and home button until phone restarts
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
Just tried that it didnt work and I also noticed I can take panoramas and they save but snapchat doesnt take pictures only video
さんによる
What version of IOS are you running?
さんによる
I'm running the most recent version 9.3.3 I think it is
さんによる
I would try updating the phone through the computer, most times when updated over the phone it can be a bit buggy
さんによる
The flash also doesn't work
さんによる
2件以上のコメントを表示
コメントを追加
I was told I need to have front and back camera replaced. When guy tested camera he said nothing wrong with cameras, what else can be the problem pls?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
It worked!!!!!!!! Thanks!!!!
さんによる
What worked ?????????
さんによる
Powering off and back on worked for me with this same problem.
さんによる
コメントを追加
My camera isn't on nor is my messenger
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem except I can’t take photos or vidoes. And I can’t delete and photos or videos either
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine dose the same thing so u held the power button down and the home button but this did not work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jeffrey claro さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 38,898
