メインコンテンツにスキップ
Appleがプロフェッショナルおよびパワーユーザー向けに提供するノートPCのラインです。現在、MacBook Proには13、14、15、16、17インチがあり、Pre-unibody(オリジナル)、unibody、Retinaディスプレイ、Touch Bar、SOC(システムオンチップ)設計によって大きな改訂が定義されています。
20011回答 すべてを表示
Need information on Kernal Panic after water Damage
Hi there,
I have a Macbook Pro here with water damage. I am unsure of the specs except that it is A1278 9,2
It was dried with rice. At first it would switch on... boot as normal but my password would not be accepted, when i tried to recover password using the recover with apple ID option it would crash.
I removed the HD. I am trying to do the hardware diagnostics with d/alt-d but no luck. I get a panic message. I tried inserting a usb with OSX 10 and still the same.
I will work out now how to attach an Image and let you see the screen...
Can anyone diagnose the fault with the information given? I would be happy to replace components but dont know which one is at fault.
Thanks!
Edit, When left to its on devices it will flash a globe for a while then restart, repeating.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Anyone know anything?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi
First of all, using rice doesn't really save electronics with water damage, unfortunately. With that said, you can try to disassemble the laptop and carefully clean up and dry out any area that seems to have some traces of water damage on it with isopropyl rubbing alcohol, being careful not to knock things off of the motherboard. Try to not keep things plugged in or powered, since that might cause further electrolytic damage in the presence of liquid. It is likely the keyboard will have to be replaced, and you can get either the bare thing or the whole top case on AliExpress for a modest price, but as always, test before replacing.
Seems like the machine still has hope, given that you still can see stuff on the display.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
S D さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 71
