メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
Help identifying the CORRECT Logic Board Part #
MacBook Pro 13" Retina Display Late 2013 -...
Howdy folks! A customer of mine has a MacBook Pro who's logic board that was damaged by water. A water bottle spilled in her laptop bag . The red water indicator under the trackpad ribbon connector is positive for water damage. I am looking to properly identify this board so I can order a new one. I thought the BEST thing to do is share a picture of her back cover so you smarties can see for yourselves what model and other machine specific identifiers.
I'd also like to ask if you know where to get parts from a REPUTABLE distributor.
THANKS in advance!
Glen
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Here is your part.
MacBook Pro 13" Retina (Mid 2014) 2.6 GHz Logic Board
MacBook Pro 13" Retina (Mid 2014) 2.6 GHz Logic Boardの画像
製品
$219.99
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
I used http://www.everymac.com to ID the computer via serial number.
さんによる
Apple Part #: 820-3476-A
@ilabbe - once you do identify a machine, it's best to correct the icon so they can get to the guides
Here's the replacement guide: MacBook Pro 13" Retina Display Mid 2014の基板の交換
さんによる
Correct the icon? I'm not sure what your mean. But THANK YOU GUYS for your help!!!
さんによる
Ahhhhhhhhhhh!!!!!!! <Screaming like a frightened 5 year old girl> $700 dollars??????? My customer will fall over backwards, BUT... now that I know the part number I suppose I can look elsewhere.
Thanks again!
Glen
さんによる
コメントを追加
You might want to finish your profile so you can establish yourself as a professional with iFixit to get better pricing. Click on either my icon or Johnathans to look at those profiles.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thank you Mayer!
さんによる
Yes, that price is way out of line and not at all in line with current prices on the marketplace. I would contact customer support and ask for a price update after you are set up as a reseller. But as you may know, other part sellers sometimes put an artificially low price on a part and then when you go to buy it find it is out of stock. Here's an example : http://www.powerbookmedic.com/MacBook-Pr...
さんによる
コメントを追加
回答を追加する
Glen Comstock さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 13
今までの合計 1,486
