メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Blue Screen After Putting It Back Together
So I've taken apart my iPhone 4s a few times now. The first was to replace a battery and vibrator, the second was to replace the audio cable, and just last night I went in there again because the silence switch had stopped working.
I've been super successful with these repairs; everything has gone off without a hitch, but last night when I put it together my phone screen was blue.
The phone actually still works. It's apparent I can navigate through the home screen by swiping left and right. It's just really fuzzy with those blue and white lines in the second image. Opening apps is trickier to judge, but I can use Siri to call my wife. So the phone isn't busted, it seems like just the screen.
Does anyone have any idea what might have happened and how to fix it, short of buying a new display or logic board? I've been successful taking this thing apart and putting it back together a few times now. I can't think of anything I could have done to damage anything. Thanks for any advice!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I'm going to go with ribbon connector has become damaged for the LCD display. You will probably have to get the screen replaced.
You can get the part from here, otherwise order where you wish:
iPhone 4S Screen
How to replace the screen just in case:
iPhone 4S スクリーンの交換
iPhone 4S Screenの画像
製品
iPhone 4S Screen
$34.99
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
It was defintiely the screen. I bought a new one and replaced it and the screeen works again. Thanks so much!
さんによる
コメントを追加
回答を追加する
James Rysinski さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 55
