Fan is not turning on - have tried different outlets, no luck.
Have plugged fan into different outlets, changed remote battery - nothing. Is there a fuse that can be replaced and if so where do I purchase and how do I replace it?
There is one timed fuse on the main PCB, but if the fan is not powering up at all, and you can hear a very faint noise coming from the base (high pitched whistling noise), then the problem may very well be the main PCB. The chip on it has a tendency to break down if the fan is not cleaned out regularly and the main plug top fuse is up rated.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 6
過去 30 日: 16
今までの合計 1,983
