メインコンテンツにスキップ
The Dyson AM07 is a bladeless tower fan released in 2014. The AM07 uses "Air Multiplier" technology to create a smooth stream of air without using visible blades.
19回答 すべてを表示
Fan is not turning on - have tried different outlets, no luck.
Have plugged fan into different outlets, changed remote battery - nothing. Is there a fuse that can be replaced and if so where do I purchase and how do I replace it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
There is one timed fuse on the main PCB, but if the fan is not powering up at all, and you can hear a very faint noise coming from the base (high pitched whistling noise), then the problem may very well be the main PCB. The chip on it has a tendency to break down if the fan is not cleaned out regularly and the main plug top fuse is up rated.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
corgimom48 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 1,629
