メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.5GHzデュアルコアIntel Core i5プロセッサ(Turbo Boost使用時最大3.1GHz)、3MB共有三次キャッシュ
One key has changed function
Hi,
This macbook pro had a little bit of water damage from using in the bathroom.
Everything works fine except one key... The @/# key has now the function "volume up".
How is this possible? Fixable? Can i change the function from settings?
Thx for your help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Using it in the bathroom !?!?! Thats not the best place to use your system.
Sadly this is not an easy fix what happened here is the soapy water got into the keyboard onto the switching elements damaging them. You will need to replace the keyboard to do this right. This is a very big job as the entire system needs to come apart. Here is the IFIXIT guide to gain access to the uppercase: MacBook Pro 13" Retina Display Late 2012 Upper Case Replacement. At which point you could take the keyboard out of the upper case and try to clean it or replace just the keyboard, or just replace the upper case.
As to how the keyboard works it uses a cross bar system (X & Y grid) so if you damage the contact board you can cause mis-keys as you encountered. Soapy water is corrosive which is why it got damaged.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mattis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 8
今までの合計 126
