メインコンテンツにスキップ
iPhoneを自分で修理するために必要なものはすべて揃っています!最新のiPhone 15から、2007年に発売された初代iPhone 2Gまで、iFixitにはすべてのiPhoneに対応する無料の修理ガイドと分解情報があります。
36474回答 すべてを表示
締切られた回答
repaired the glass, made connections...phone wont turn on
followed the directions and watched the video a million times, repeated all the steps put the 3 ribbon connectors back on and snapped into place, the phone will vibrate occasionally but will not come on..At my wits end...keep repeating the last steps to no avail...Please help..
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
ribbon 3 doesn't slide all the way in, some bronze will show. ribbon 1 is for lcd-is this loose? check for dirt or bent pins on ribbon and on board. have you got the right part? is this a first generation/3g or 3gs. the parts are not interchangeable. if all these things are right then it may be the part is faulty or you have damaged the new lcd during installation.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
is the phone still ecognized by iTunes? if not, there must be a problem with the dock onnector ribbon, try to test the conection on this one. it is the larges connector inside, on te top of the dck connector...
Update
if the ribbon does not slide in, it does not matter. that ribbon is only for mic and proximity sensor. its those two other connectors. those two must be seated fully, otherwise it wont work...
does it get picked up by itunes? did you try to reset it?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
you might need to rset the phone. press home button with power nutton together, hold them until you can see apple logo. it should tak about 10-15 seconds
さんによる
it rings but the screen is black...ribbon 3 wont slide all the way in, some bronze is still showing.., is this or my lcd..???
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 828
