メインコンテンツにスキップ
The Atari 2600 or Atari Video Computer System (VCS) is a video game console released in September 1977. The 2600 runs a MOS Technology 6507 CPU and uses ROM cartridges for storing games.
What are the screw sizes for the case?
It looks like the case has four screw holes and all the screws are missing. Mine is a sears tele-games console, but I think it's an exact clone of the 4-switch atari 2600. I'd like to know the screw sizes for the case so I can put this thing back together properly!
Update
Here are the exact screws I ended up using, in case anyone else needs the info. #6x3/4" from Lowes. Model #: 490198
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Give me a second, I'll dig out mine and take a picture of the screw for you.
さんによる
コメントを追加
3件の回答
ベストアンサー
Here you go, it's about 3/4 Inches long. I put it next to an SD card for reference.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
And all 4 are the same
さんによる
コメントを追加
I measured the screws on my 4-switch Woody and Vader.
The short answer is you need four screws of size #6-20 (aka #6) in length of 5/8”. Details below…
Quantity 2 #6-20, ¾” length screws are at front.
Quantity 2 #6-20, ⅝” length screws are angled at rear. They are installed at an angle, parallel with the silver switches.
I think you could use ⅝” long screws for all four locations but factory used longer ones up front.
Measured sizes to help folks convert to metric…
Diameter 0.136 inches
19.7 threads-per-inch
Length: 0.725 inches and 0.600 inches
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for confirming, just found this via brave browser search.
So for metric it will be M3.5 width (mine looked like 3mm but measured 3.4 so came here to confirm) .
For the Sixer consoles = 6 screws of 16mm (blunt tip) and 2 screws of 20mm (sharp tip).
The two 16mm screws in the middle of the console go with washers (these are part of the faraday cage securing from the outside, so leave those middle holes empty when working on cage)
If you find stainless steel screws, best to grease the ones that contact other metals, incase of bi metallic corrosion.
さんによる
コメントを追加
Thanks man.. Heading to LOWES now!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chris O さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 47
今までの合計 3,936
