メインコンテンツにスキップ
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
561回答 すべてを表示
Is this burnt logic board damage localized or extensive?
This logic board had some minor localized water damage, after which one of the components sparked and burnt itself. I asked in a separate question for confirmation that the burnt component was a 220 Ohm inductor, and got a good answer.
Now I have some detailed magnified photos, and I wanted to ask if the experts can see if this is localized to just the component, or if anyone thinks just replacing that component will not be enough, or will not be a simple process now.
Since this is one component, and at the edge of the board I feel confident doing it myself, but I'm not sure what the other circles near the component (see the photos of the same board in good condition for comparison) are from and the burn damage looks like it covers those too.
Any advice would be greatly appreciated. Thanks...
Magnified comparison of damaged board and good board:
Damaged board (that is the only moisture tag on the board that went red):
Good board:
Board diagram area:
Component on Schematic:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
It appears to me that if you replace that inductor( I think it's actually a ferrite bead type of inductor), you will have a working computer. The chip at the other end of the lcd connector looks a little crusty, I'm not sure if you will have problems with it or not. I think you have the wrong board view though. It has components that aren't on your board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Peter Miller さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 112
