メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
No Service After Housing Upgrade
A few days ago I transferred my iPhone parts to a black + gold rear housing, and everything was perfectly fine until today when I took it to work. The majority of the time it says "No Service", and hangs when there is service. However, when I take it upstairs, it works perfectly fine. Everything was also working properly when I was at home. Any idea what I could've done wrong? Prior to this T Mobile was connecting just fine here. There were one or two screws I put in the wrong place (like a 1.5mm screw in a 2.1mm pot), as well as some screws left over. Maybe I scratched a resister off?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The screw posts on the rear case must not be colored, otherwise it won't be conductive and you will lose the antenna structure, especially LB/MB cellular diversity, 2.4G, GPS and NFC.
If the screw posts are colored, clear the paint with a dental drill. Install all the screws and contact washers, they serve as antenna connectors.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Anun Azganun さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 149
