メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
After water damage no function but board seems working.
Hi guys,
I am repairing an iPhone of a friend and I now faced a problem I'm not familiar with.
Short version:
Phone remained in a jacket outside during rain. Since then no function. I opened up the phone but there was no corrosion visible. I put the board into my iPhone 6 and run it. Since it turned on the board should be okay.
I tried to find defect parts by exchanging them. I put a new battery, power button cable, lightning dock cable and volume buttons cable in. But still no reaction. Neither by pressing the power button nor by plugging in the USB cable. Even iTunes keeps silent.
Does someone of you know any component that be causing the defect I not exchanged, yet? Or could the housing cause the problem? I'm like 404...I'm thankful for every further idea :)
Chris.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
If you have access to another phone as you say you tried the board in another phone try testing the display. Water damage is not restricted to the board .
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Oh I didn't mentioned but as I switched the board I also used the display of the "damaged" phone. The display should be okay as well.
さんによる
so the display and the logic board both worked in another phone? connected together in that phone?
さんによる
yes. both worked in my phone.
さんによる
コメントを追加
回答を追加する
chris9211 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 95
