メインコンテンツにスキップ
テレビのHDMIポートに直接、接続する小型メディアストリーミングデバイス。2014年11月にAmazonから発売されました。最新バージョンには、音声起動リモートが付属しています。
20回答 すべてを表示
How to open FireTV Stick remote
Any creative ideas for how to open the fireTV Stick remote when you first get it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
コメントを追加
5件の回答
最も参考になった回答
The two best options, as it turns out, are 1. Just pull really hard, or 2. Use a screwdriver to pry it open.
Here is a YouTube link that shows how:
https://www.youtube.com/watch?v=F__fFr7n...
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
I went down the screwdriver route. Many thanks for the suggestion.
さんによる
コメントを追加
Simple once you know how. Hold BOTH ends of the remote, squeeze both ends gently and slide forwards
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I agree. Sometimes, the new plastic pieces have micro texture edges resulting from the fresh cutting from the making of the pieces that give it a bit of a grip against each piece to where you will need to use something that allows you grip it better, like rubber gloves, or even a rubber band. I too had serious trouble opening it the very first time. I used latex gloves to open mine once, after that I could open it easily with bare hands. If you put a rubber band on your thumb and push it open that way, my bet is that it will open for you.
さんによる
Latex gloves worked - still have to push hard - Thanks
さんによる
コメントを追加
The person who designed this remote should be fired. Seriously.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Couldn't agree more. It's totally ridiculous for such a sophisticated device to be missing a little notch to open it easily.
さんによる
コメントを追加
I received the Amazon fire stick remote today, and took me quite a while to figure out the best way. Every time I press on the indent and move it up it opened a teeny weeny bit, and not any more. So finally, I pried it open a little and put in the batteries
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Phew! Ridiculous! Took suggestion from YouTube & used rubber jar opener to gain traction while pushing down-still very tough!
さんによる
コメントを追加
Watched a video on YouTube with a very simple trick that works great. Turn the remote over so the little arrow is pointing up. Grip it firmly in your hand and hit the end firmly on a hard surface. If you do it right, the back cover pops right off. I got it off on the first try.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mitchel Szazynski さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 77
今までの合計 36,633
