メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Loud Speaker not working after housing replacement
Ive replaced the housing on my phone right away the loud speaker was having problems when on low some sound will come out but when I put the volume up nothing come out at times when the battery is low and I attempt to hear something the phone completely loses power I've tried replacing the speaker and that did not work if anyone has a solution please share there are others with the same problem thank you in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
5件の回答
最も参考になった回答
Both the answers above are good ones, but make sure of two things that your dock connector assembly cable is in good shape, and that the connection to the logic board is sound. Having the speaker working and fine does you no good if your connection to it and the power source (the battery via the logic board connector) is bad. You may need to replace the dock connector assembly cable and when you do this you will have a chance to check out if the speaker is aligned correctly and is making contact with the connector. Get a good magnifying glass or a microscope to check the pins on the logic board connector and the pins on your dock connector cable. If they are bent, broken or crossed that might explain your loss of power issue. Sometimes small bits of metal dust can get lodged into the pins and case all kinds of issues. To solve some of these issues though you need to replace the whole dock connector assembly just to get things working again.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Are the dock connecter and the loud speaker alligned correctly?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi I had this problem to and it was resolved by slightly moving the loud speaker to the left or right. More so the left. There is a little room for play when re-installing the loud speaker. You also want to make sure the the cable is exactly where it should be.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I solved this by changing the entire charging port.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
bro change your loud flex cable which is lubricated at housing panel
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Big bear さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 2,367
