メインコンテンツにスキップ
Galaxy S7 Edgeは Samsungの2016年最新モデルGalaxy S7のスクリーンがカーブしたデザインです。2016年2月に発表、同年3月11日に発売されました。モデル番号はSM-G935です。
20回答 すべてを表示
Seal broken? Is theyre a way to re seal it?
Hey so I had my phone fixed by a shop last week. They used a very poor adhesive to Seal the back on from where I dropped it and shattered the back glass . Is they're anyway to seal this phone back so that it may be used in water? Being that the phone has a water pressure level and a time the phone is able to withstand water ? Used it before in the water and I didn't have a problem. I was going to try this other place called I fix it near me. THey said the seal would be stronger but theyre no guarantee that the phone can go back and water without a case protecting i
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
ベストアンサー
Nobody can guarantee waterproofness of a phone after repairing it. Your best bet is to use the original back cover adhesive.
Pretty sure Samsung has that hardware test hidden menu which you can access from typing the secret dial codes that allows you to test the air pressure inside the phone for waterproofness. If the air pressure changes when applying pressure at back or front of screen then it's waterproof. If it doesn't change then it's not.
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
Where would I get the original all adhesive?? So your saying samsung has that in a hidden menu?
さんによる
I thought it was if the air pressure changes then it is waterproof?
さんによる
Fixed up my answer.
さんによる
what test do you use to do that? I mean which one to I click? I found the code
さんによる
コメントを追加
There's a company on ebay (although they are located in the united kingdom) that sell only OEM Samsung service parts, whom I buy all my adhesives from. There name is; fonejoy and there ebay number is 134821. I'm having a guess that you have a S7 or S7 Edge so I have included the part numbers.
SM-G930 Back Glass Adhesive -
GH81-13702A
SM-G935 Back Glass Adhesive -
GH81-13556A
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
So, hey, I know that this conversation, if you will, all took place in 2016 but with this sanitize-everything new world this problem is still real. Love & will use the answer but can't find a way to close & lock her down again. What tool do I need to apply to get the tightest of seals I need? Please and thank you.
さんによる
コメントを追加
Regardless of if you use the original adhesive you still need that adhesive to adhere to the frame like it would coming out of the factory. Bearing in mind the frame was brand new and possibly pressed down with some sort of machine.
I'm sure Sony don't guarantee the device will be waterproof after repairing it themselves.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Yeah, not sure Sony would guarantee a Samsung device.
さんによる
Yes... great observation. Clearly using sony as an example as they publicly offer a repair service to more waterproof devices then anybody else
さんによる
コメントを追加
回答を追加する
Samuel Kennedy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 12,065
