Hi Timothy,
Both the i5-6500 and the i5-6700 are of the socket FCLGA1151 form factor, so theoretically, the upgrade should work.
I say 'theoretically', because while on a standard x64 motherboard, running Windows or Linux, it most definitely would be fine.
However, Apple make it their business to wilfully prevent as many consumer upgrades and repairs as is humanly possible. For example, they have started soldering SSD drives onto motherboards, and in some cases, RAM. It would not surprise me at all if this had been prevented, but if you've read that it is, you may be ok with it.
To clarify, the problem (if indeed there is one) isn't generically a hardware compatibility one - it's whether Apple have, on purpose, prevented CPU replacement. Focus your investigations in this area.
Sorry that's not comprehensive, but I hope it helps you look for the relevant info.
4 件のコメント
Here's your systems specs: iMac 27" 3.2 GHz i5 5K Display (Late 2015)
Dan さんによる
First you'll lose your warranty unless Apple or an ASP does the work. Please tell us you RAM configuration your storage situation, how full the drive is and what seems to slow you down (apps). Also do a force quit and see how many programs may be running in the background ( command, option, escape).
mayer さんによる
Thank you very much guys for the answers! I already upgraded ram to 24gb and running 256gb internal ssd with it which I did CTO before I bought it.
Loosing warranty is very scary but if it's possible to replace for sure, I probably will replace it.
Like 'DeathOnRedBull' said, I'm worried if Apple dropped socket on a lower-end model, therefore I cannot replace cpu on mine. Maybe I should thinking about other alternatives...
timothy さんによる
The only other choice other than doing something externally, is to sell your system and get a system which has the higher end CPU & Storage. You may want to consider a Mac Pro system instead, it is a lot easier to upgrade its internals than the newer iMac's.
Dan さんによる
