メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Beats Pillの第2世代モデル。カリフォルニア州でAppleが販売。2013年発売。モデル番号:BO513.
Why won't my pill charge?
All of a sudden my pill won't charge,I didn't drop it nor is it damaged.Can you help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
The battery has 4cables in a block connected to the circuit board pull this block out of the circuit board then reconnect. I'm pretty sure mine had just vibrated loose,beats pill worked straight away and taking a charge.
さんによる
コメントを追加
2件の回答
ベストアンサー
Here's how to get into it. Look for the number on the battery:
https://www.youtube.com/watch?v=Jh3VWvA3...
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
I have met the same problem, my beats pill 2.0 won‘t charge and out of warranty. After watching this video, i bought a replacement battery from amazon and replaced it by myself, it works great. Thank you. The battery's ASIN is B01MXDCSXT, you can search it on Amazon.
さんによる
コメントを追加
most likely, the battery has gone bad.
i am searching for one myself, but its starting to seem that you have to send it back to apple for battery repair\replace..
Update (12/04/2019)
just to add a bit.. you will also need to be comfortable soldering and unsoldering the battery leads.
if you can do that, should be a fun project.
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
after some digging, i found that the pill takes 2 batteries and are almost the exact same size as a gopro hero 2 battery. you have to take the cover off the gopro battery to get it to fit, but it will work.
you do need to be comfortable with taking apart small parts and possibly modifying the case a tiny tiny bit to get it to fit, but it does work..
さんによる
Does it Cost money if you send it back for a battery replacement
さんによる
Send it and let us know if they do it for free...
さんによる
Only if it is out of warranty
さんによる
How much does it costs if it's out of warranty?
さんによる
コメントを追加
回答を追加する
Joe Wright さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 34
今までの合計 40,592
