メインコンテンツにスキップ
Cuisinart Griddler GR-4N a five-in-one kitchen appliance to be used as a contact grill, panini press, full grill, full griddle or half griddle .
16回答 すべてを表示
Why is the device cooking unevenly?
The device is cooking the food unevenly. I think the heat is not being distributed evenly throughout the cooking surfaces.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
If your cooking surfaces are not heating unevenly your plates may have begun to peel. If this is the case they must be removed and are are in need of replacing. Your cooking surfaces and heating coils may also be out of alignment and need to be realigned, this guide will take you through the steps to do so. Additionally, you may need to just make sure that the cooking surfaces are held in place by both of the metal clips on either side of the plate. Refer to the following guide for more information Cuisinart Griddler GR-4N Cooking Surfaces Replacement
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kayla Londono さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,447
