Why is my coffee not hot enough?
Whenever I try to use the Keurig, the coffee doesn't come out hot enough. Please help:(
The temperature can also be set on the display via the menu but it is generally a sign that something else isn't working.
このアンサーは役に立ちましたか?
Why isn't my coffee hot
このアンサーは役に立ちましたか?
If you change it in menu to 192° and it still comes out cold, go to ebay. For 20 bucks you can get a new tank/boiler, usually ships free. Not a fun repair but doable easily once the case is off
There might be three possible reasons if your Keurig is not hot enough
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 19
過去 30 日: 104
今までの合計 15,374
1件のコメント
It's not hot when I finish brewing
Adele Martin さんによる
