How to change the glass of magic trackpad2
I accidentally make my magic trackpad 2 glass cracked.
I still can use the magic trackpad 2 without any issue,just the glass cracked
how can I fix this?
この質問は役に立ちましたか?
how can I fix this?
この質問は役に立ちましたか?
Sadly Apple (or other part houses) don't offer spare parts for the trackpad. You'll need to buy a new one.
このアンサーは役に立ちましたか?
I contacted some glassmakers to make a sample and after replacing the glass myself, it worked great! I resurrected my Magic Trackpad!
Review the guide here: [無効なガイドリンク]
このアンサーは役に立ちましたか?
Hi
Sadly there aren’t really any repair guides of the Magic Mouse however,this isn’t really recommended be on eBay there will be lots of faulty ones you can use as a donor so if your up for a challenge find a YouTube video or follow a teardown and see how far you get
Like I said previously this isn’t recommended but it’s up to your self if you want a shot and if you need any advice please do not hesitate to ask
このアンサーは役に立ちましたか?
@hellomacos - There is a guide! And a parts source too! @applerepaired put in the effort for the guide and has the needed replacement glass.
That’s amazing Dan!
Well done to @applerepaired for finding this information!
Thanks for the support!
過去 24時間: 3
過去 7 日: 6
過去 30 日: 16
今までの合計 5,619
2 件のコメント
Hi,
I have the same problem, how did you solve it?
Thanks.
Cristian Palazzolo さんによる
@palazzolo - I'm sure they replaced the trackpad unit.
Dan さんによる
