メインコンテンツにスキップ
A 10 speed mixer made by KitchenAid in 2006.
28回答 すべてを表示
KitchenAid Professional 600 mixer not turning on?
Every time I try to turn on my KitchenAid mixer nothing happens. I've tried unplugging and plugging it back in but nothing happens. I even checked to see if it was a faulty outlet but the outlet works fine. Help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
2件の回答
ベストアンサー
The wiring of the outlet plug may be faulty and in need of replacement check out our trouble shooting page for help! KitchenAid Professional 600 Troubleshooting
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
One easy thing we see a lot is the mixer has to be in the off position when it is plugged in, or it will not turn on. It's silly but you would be shocked how often we see this. So, turn the mixer off, unplug it and plug it back in and see if it makes a difference.
If not, you are most likely looking at a bad speed control board, though you could need a new cord or motor 95 % of the time it would be a bad control board.
You can find the service manual and parts online at kitchenaidexperts.com
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Luke さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 33
過去 30 日: 146
今までの合計 6,148
