Odor and smoke during first time use
On the first time use, My Cuisinart GR-4N Griddler began smoking and created a slight odor. Is there an issue with the device? Are there any necessary replacements?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sometimes cooking items do give of an odor the first time they are heated up. Sometimes a little contamination on the cooking surface. It's kind a matter of where the smoke was coming from, inside or outside and if it smelled like wiring insulation burning. Please give us a better description of the symptoms and if it worked or not.
このアンサーは役に立ちましたか?
The Cuisinart Griddler GR- 4N cooking plates are nonstick surfaces and it is normal for nonstick surfaces have a smell and smoke a bit. Try cleaning the surfaces off and using it again it is unlikely there is a real issue with the device.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 10
過去 30 日: 59
今までの合計 3,302
