Why wont the record player read the disk?
The record is spinning and the tone arm is on the record but there is no sound.
The record player wont read the disc either because of the record it self or the needle/ cartridge needs to be replaced. First, try a few records and see if they all play or not. If they do, your all set but if they don't then you need to replace the needle. Following Needle/Cartridge Replacement will allow you to replace it
このアンサーは役に立ちましたか?
@jroche2 nope. definitely not the record. Nothing to read like a CD etc. Records only failed in a case of scratches or skipping but never not making any sound. There will always be sound for as long as you have a proper stylus and pickup.
The Jensen JTA 230 is a self-contained player and if the stylus etc. should be okay then you will need to check the amplifier inside the turntable
過去 24時間: 0
過去 7 日: 1
過去 30 日: 18
今までの合計 1,713
2 件のコメント
@lvarrichione I understand that you are most likely not old enough to remember how these things were supposed to work. The JTA-230 is actually called a turntable and it uses vinyl records for playback. No disk reading involved since the stylus "needle " actually sits on the record and sense the groves cut into the vinyl. Check this out Meredith Bower "How Record Players Work" 7 December 2009. HowStuffWorks.com. <http://electronics.howstuffworks.com/rec...> 2 May 2016
oldturkey03 さんによる
Thank you for your information oldturkey03. I believe the terms disk and record were being used interchangeably here. For lack of a better phrase "Reading the disk" was said instead of what the device actually does. Understanding how the device works allows for better troubleshooting and identification of a specific problem.
Robert Wilcox さんによる
