メインコンテンツにスキップ
二輪車、自転車の修理ガイド。特定のモデルを検索するか、関連ページのセクションでトラブルシューティングのwikiを参照するか2つの方法を使ってガイドをご利用ください。
139回答 すべてを表示
When pedaling, the back tire locks.
You start to pedal and it feeels as though you just braked forward. Back tire will not turn as though chain locked up
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
when i pedal forward my chain or my back wheel wont move
さんによる
コメントを追加
2件の回答
最も参考になった回答
Sounds like you may have a bad set of bearings. You will need to:
  1. remove the rear wheel from the bike by loosening the axel nuts and the coaster brake
  2. then remove the axel from the wheel, there should be a retainer clip that can be removes from a groove in the axel, once removed, the axel should slide out.
  3. before going further, clean the grease off of the hub and look for some numbers on the inner hub. Most likely the numbers will be 6XXXZZ or 6XXXRS (where the X's will be replaces with numbers) The ZZ designation represents a shielded (metal) bearing set, and the RS represents a sealed (rubber) bearing set. make a note of these numbers, you will need them to order the right size and type of replacement bearings
  4. drive the old bearings out of the hub using a hammer and punch (don't worry about damaging the bearings, you are putting new ones in, but be careful not to damage the inner hub)
  5. install new bearings (these are friction fit, they should just push in. occasionally requiring a tap from a rubber mallet, make sure you put the spacer back in between the bearings if there was one)
  6. re-install the axel (don't forget the retainer clip)
  7. re-install the rear wheel, attach the coaster brake, make sure that the chain is in alignment, and that the wheel spins freely.
  8. tighten the axel nuts
You are done! Congratulations.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
URGENT HELP NEEDED PLEASE!! Hi, Im trying to reinstall a coaster wheel with the same problem,its not the bearings as the wheel was rotating forward before i took out of the frame to fix a puncture,have i maybe overtightend axle bolts (could this affect cone nuts?) or not tightened/secured brake arm enough/properly? Im a coaster brake newbie mechanic wise and its the first time ive put a coster wheel back on so would be really grateful for any advice. thanks Steve
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
moniqueward083 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 108
今までの合計 17,626
