How can I replace the control board for kenmore elite he3 washer
the control board of my kenmore elite he3 is bad and i would need a replacement, but i do not know how and where to get it
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@chrismatthew use this guide for the board. Download the manual from the bottom of this page. Page 4-2 pf the manual will show you how to further access the components. Depends on your location, the parts should be available at places like this or on here as well as many others.
このアンサーは役に立ちましたか?
Are you getting an f dL code? If yes, you probably dont need to replace the CCU. I found video on youtube showing how to remove top portion of cabinet. I unplugged washer, remove top of cabinet, and carefully unplugged each one of the plastic clips for all the pink wires (one at a time) and plugged them back in. This worked temporarily! I read a post online that claimed this problem was a design flaw/vibration causes the plastic seats to become loose and not make proper connection. I got some electrical tape, cut a long strip for each relay seat, and (sticky side facing up) carefully placed the middle portion of the strip under the relay seat, pressed to ensure good contact, and brought each end up (with a little tension to keep plastic seat in place)/crisscrossing so ends would stick to top of CCU and back of top cabinet. Washer locks door and runs like new! I didnt need CCU or new door lock mechanism. Thank you to everyone that contributed to the online posts. Saved hundreds of $ with this simple easy fix!
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 10
過去 30 日: 42
今までの合計 3,589
