camera will turn on , red light at the back stays on.
camera turns on . but wont take a photo . red light at the backs stays on . and the light for brightness setting doesnt go on. tried to replace a set of batteries. didnt do anything.
The red light is the Low Battery indicator.
このアンサーは役に立ちましたか?
Where could I take my camera to get it checked? I am having the same problem, the red light is on but the settings lights does not. I also recently dropped it , but I hope it's not broken.
My camera just bounced off my bed and fell on my laptop. it looks like I'm my the only one who's experiencing this after it falling. The batteries seemed fine, what should I do?
Thanks! I actually dropped my poloroid a while ago and thought that was the problem but it turns out I hadn’t changed the batteries. Really helpful thank you!
What if my camera doesn't work and I just replaced the batterys with new ones and it's still not taking pictures? Can you please help me
On my Instax 9 I take a picture and the red light turns on, then the camera makes a buzzing sound like it’s going to print the picture, then it doesn’t. The back where you load the film kind of pushes on the case and when I open it i hear some spring go back into shape or something?
このアンサーは役に立ちましたか?
Me too!! It’s happened when my film stuck in the camera bcs the battery died suddenly. Have u solve ur problem?
このアンサーは役に立ちましたか?
If you look inside of the battery chamber, it says to either use LR6 batteries, or 1.5 Volt batteries. I hope I helped
このアンサーは役に立ちましたか?
Thanks for this answer! It turns out that i wasnt paying attention to the batteries i were grabbing from the container, and mustve grabbed dead ones when i was trying to replace them lol. That probably doesnt make sense, but if i hadnt looked up what the solid red light meant, i woulnt have replaced them. Thanks again
このアンサーは役に立ちましたか?
mine stays red but my batteries arent dead. i dropped them on the floor and they are fine. Maybe something else???
このアンサーは役に立ちましたか?
Try 1.5 volt batteries or LR6 batteries
i have the same problems the red light on the back wont stop i cant take a pic bc it wont turn off and i changed batteries but it wont work either it still stays on my Polaroid is the mini9
このアンサーは役に立ちましたか?
i have the same problems the red light on the back wont turn off it will only turn off if i push it back i tried changing the batteries it still wont work pls tell me how i could fix it
Make sure the bat your using is a quality brand with 1.5 volts.
I had the same problem. I was trying to use a rechargeable bat which had max voltage off 1.3v
このアンサーは役に立ちましたか?
I changed my batteries and it ended up being i had the plus and minus signs mixed up! I hope this helps. I was worried it broke! So glad it was just this.
このアンサーは役に立ちましたか?
I’m having the same problem and even have new 1.5 volt batteries in but it still doesn’t take pictures. Anyone know how to fix it?
このアンサーは役に立ちましたか?
I have put new alkaline batteries in, the right way. And my light on my camera is orange, It is not blinking. When I take photos they only show up white, even in a dark room. I am not covering the light sensor or anything. What is wrong?
このアンサーは役に立ちましたか?
過去 24時間: 82
過去 7 日: 735
過去 30 日: 2,906
今までの合計 237,440
6 件のコメント
Mine does the same thing except the brightness setting lights just all blink orange. And it will not take a picture. The film counter also will not reset with a new case of film?
Destiny さんによる
My Polaroid just flat out will not turn on. It is brand new and i have tried to change the batteries. The red light will not turn on
Albert さんによる
just got my camera today I put the batteries in that came with the camera it only took 2 good photos then the rest turned out black I’ve tried everything nothings helped
haileyjune555 さんによる
Can you use batteries that have been recharged in your instax mini as well
Aderemi Eriifeoluwa さんによる
Keira Thorsteinson さんによる
1以上のコメントを表示
