Front seat belt relay switch
How to replace front seat seatbelt relay switch on a W123 Mercedes 300D
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Ken,
If you mean the relay that turns on/off the seatbelt warning light, and also the buzzer, it is located up under the kick panel beneath the steering wheel aka on the driver's side.
Use this guide to remove the kick panel on that side:
Disassembling Mercedes W123 Kick Panel
Then look for a silver box about the size of a pack of cigarettes, mounted almost all the way to the left near the driver's side door. This is the seatbelt relay. Note that there is another silver box, that is thinner but taller/wider, which is tucked up a bit further back in the dash. This is the cruise control box.
Once you've located the seatbelt relay, it's just a matter of unscrewing it and unplugging it and the reversing that to install the replacement part.
このアンサーは役に立ちましたか?
Do the European model have this feature?
I've read somewhere that it doesn't.
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 787
