メインコンテンツにスキップ
北米で2010年3月に発売されたニンテンドー DSiの大型版モデルです。ほとんどの修理作業はドライバー一本と開口ツールのみで完了できます。
My DSi XL will not charge
Hi there,
My DSi XL works good except when I connect the charger the charge light only blinks once then shuts off.
I changed the F1 fuse near the power connector with no success. Is there another fuse F2 or something?
Regars,
MC
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
5件の回答
ベストアンサー
Yes, F2 is on the underside of the battery PCB; you'll have to remove the screws and take the board out to see it. It fails quite often, producing the result you see.
You can either replace it or just solder a wire across it to bridge it.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Hi, um I do not understand a single word you said and I'm having the same problem. Can you simplify the answer for me please?
さんによる
The dsi xl has 2 fuses. 1 is marked f1 and found just under the charging port on the main motherboard.
A second fuse (also marked f1) is found on the underside of the power supply board (the smaller one on the left if you have your ds open in front of you.)
If either of these fuses is faulty, your ds will not start. They can be tested with a multimeter, and if necessary replaced with some careful handling and a soldering iron. The power supply board is screwed to the casing, so you will have to unscrew those to check the second fuse (also marked f1, presumably a mistake Nintendo made, as the second fuse is marked f2 in other models)
If you are unsure on how to reach the second fuse, you can check the guide on this website for replacing the power supply board. Good luck!
さんによる
コメントを追加
I don't think this is related to a fuse. It sounds more like your connection is loose or dirty. I'd suggest cleaning the charge port on the DSI with a small brush + isopropyl alcohol. If it's still doing the same thing, you probably have a bad solder connection on the charge port. A bad charger is also a possibility.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had the same problem. Checked both fuses - they were ok. Cleaned the battery poles with an eraser, ok after that...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
its hard for me because when i put my charger in i have to push the wire back so i cant go on it anymore!!! it is sooo annoying
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Where do you have to push the wire back so i cant go on it anymore! Are you talking about having to push it far into the charging port?
さんによる
コメントを追加
Hi. I'd like to ask that which fuse compatible with F2? And Where can I buy it?
thank you
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
While a quick google will not tell you exactly what type of fuse nintendo is using, it does give a number of results to buy one
an example:
https://www.amazon.com/BisLinks%C2%AE-Fu...
Not sure if it's your best bet, but amazon or ebay in general are usually a good place to look. Another option is buying a broken ds to scavenge for parts, due to their age you can sometimes even get them for free...
Good luck on your repair!
さんによる
コメントを追加
回答を追加する
Mark さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 81
今までの合計 31,436
