Why power battery is got too hot?
i did factory reset on my phone after that, i can't switch it on full complete and display, but it appears HTC only for long time, help?
sometimes it tells android system errors, how can i fix it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Phone heats up a lot if the system software is stuck in a boot-loop or is stuck at a certain stage of booting where it cannot proceed further due to system software corruption.
Not really sure of a solution to this problem. You can try using another charger, cleaning the charger port socket with a toothpick, use another charging cable. Try another battery.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 95
